From Google Merchant Center
Solve problems automatically
➔ Log in to your Merchant Center account, click on the tools icon to access your settings
➔ Select Automatic enhancements under Settings
➔ On the next page, you can enable automatic item updates for pricing, availability, status or any combination of 3. You can also completely disable automatic item updates.
You can also use feed rules to correct missing or incorrectly formatted attributes in your feed without modifying its content.
From the PrestaShop back office
Open the Prestashop Marketing with Google application and open the Product feeds tab.
Click on "Non-compliant products" to access the product details that have not been sent to Google.
You will arrive on this page:
In this example, the products are missing an identifier. If you click on the icon in the "Actions" column, you'll be redirected to the product data page, where you can add an identifier.
Comments
0 comments
Please sign in to leave a comment.
