Before using PrestaShop Payments, make sure that your store and account meet the necessary requirements.
Prerequisites
To use PrestaShop Payments, you must have:
- a compatible PrestaShop store;
- an accessible and properly configured store.
A PayPal Business account is required to use PrestaShop Payments, but you don't need to have one before getting started: you can create one directly from the module, where you'll be guided through the process. The account must be located in a region where PrestaShop Payments is available.
PrestaShop Payments is compatible with PrestaShop 1.7.7.0 and later versions, as well as PrestaShop 8.0.0 and later versions.
Install PrestaShop Payments
The process depends on your version of PrestaShop.
PrestaShop 8.1 and later versions
PrestaShop Payments is included in the PrestaShop installation.
You can access its configuration from your back office.
Earlier versions
Depending on your version, PrestaShop Payments can be installed as a module.
Once installed, you can access its configuration from the back office.
Activate PrestaShop Payments
From your PrestaShop back office:
- Log in to your administrator account.
- Open Settings.
- Select System.
- Open PrestaShop Services.
- Select PrestaShop Payments.
- Follow the steps provided to start the configuration.
Connect your account
During the configuration, you can select or connect your payment account.
Depending on your situation, you may be asked to provide information about:
- your business;
- your contact information;
- your business activity;
- your tax information;
- the business's beneficial owners;
- your identity;
- certain supporting documents.
This information is required to carry out the checks associated with your account.
Once configuration is complete
After connecting your account, you can access the various PrestaShop Payments settings.
In particular, you can:
- view your account;
- configure the available payment methods;
- manage payment settings;
- view balances;
- track payments;
- manage certain order operations.
Note
The available payment methods and features depend on your country, your account, and the services activated.
If a service doesn't appear in your back office, it may simply mean that it's not available for your configuration.
