You will find most of the server configuration information in your back office, under Advanced Settings > Information.
For a more detailed assessment, you may also use our system requirements checker tool to easily verify whether your environment meets the prerequisites for PrestaShop. Here is how to proceed:
Download the latest version from GitHub.
- Extract the zip file.
- Upload the file
phppsinfo.phpon your server and place it in the directory of your current store or in the one where you intend to install it. - Open it in your browser.
http://your-domain.com/path-to-your-prestashop/phppsinfo.php). - Enter the username and password if prompted (use "prestashop" for both).
You will obtain a page detailing the prerequisites and recommendations, as well as the current status of your server in relation to these elements.
To learn more about the PrestaShop prerequisites, please refer to the article System Requirements for PrestaShop.
