500 errors after updating or installing modules are often due to one or more of the following elements:
- Compatibility between Modules: Some modules may not be compatible with each other or with your version of PrestaShop.
- Site Cache: An outdated cache can cause conflicts after an update.
- Code Conflicts: Modifications in module files may conflict.
- Incomplete Updates: Sometimes, updates do not complete properly, leaving corrupted files.
Solutions that you can implement
Check Module Compatibility:
- Ensure that all modules are compatible with your version of PrestaShop.
- Disable the recently installed or updated modules one by one to identify the one causing the conflict.
Clear the Cache:
- Via FTP: access ./var/cache and then delete the /prod folder.
- Via back-office: In Advanced Parameters > Performance, click on Clear Cache.
Activate Debug Mode:
- Via FTP: access ./config/defines.inc.php and then change the value of 'PS_MODE_DEV' to true.
- Via back-office: In Advanced Parameters > Performance, activate Debug Mode.
Restore a Backup:
- If you have a recent backup before the modification of the modules, consider restoring your store to that state. This is a last resort, as you risk losing data!
If these solutions do not resolve the issue, you can also consult the article that addresses more general 500 errors: Fixing a 500 Error.
We also offer Advanced Technical Support, which includes a comprehensive diagnosis and a personalized resolution of your issue. If you have any questions or wish to proceed with this option, please do not hesitate to contact us.
