You can add your promo code either on the cart page or at the payment step.
| 📝 Unless otherwise stated, promo codes cannot be combined with each other; they are limited to one per order. |
My code isn’t working, what should I do?
If there is a problem with your code, an error message will indicate the cause. Among the most common errors, your code may:
- not be usable on the contents of your order
- have already been used or be expired
- be linked to a minimum purchase amount
- be attached to another specific customer account with which you must be logged in
If these items do not seem to be the source of the error, feel free to contact our support team with a screenshot of the error message.
